LotW Upload With Different Account
Posted: 08 Sep 2013, 16:06
by OE6CLD
Hi all,
My main LotW account has been created with OE6CLD. Later I added OE6Z (contest call), and a few years ago, after moving to Ireland, I also added EI7JZ. At the moment I am mainly active using EI7JZ but still use my Austrian calls when on holidays.
LotW upload with Log4OM is fine, because TQSL will use the correct callsign assigned to the user id and station location. For LotW downloads the same information will be used (in my case EI7JZ and the password), which does not work. I therefore have to manually change the callsign (= user id) in the LotW download form to OE6CLD, otherwise the LotW login will not work.
Next Log4OM will download everything it has received (from all callsigns in my LotW account) since the last update.
Begin ADIF generation request
ADIF request accepted
ADIF document downloaded
ADIF document parsed: 74 qso found.
QSO NOT FOUND : W1YRC 001600 19931031 40m SSB
QSO NOT FOUND : WW4LL 025300 20121027 40m PHONE
QSO updated : Call: MJ/EA1SA Date: 20110612 Time: 182600 Band: 40m Mode: SSB
QSO updated : Call: YB0DJ Date: 20130827 Time: 143300 Band: 15m Mode: SSB
QSO NOT FOUND : DH5SBL 160900 19910330 10m SSB
QSO NOT FOUND : IK6FTZ 174300 20130122 20m SSB
QSO NOT FOUND : 3B7RF 013800 19980516 80m CW
QSO NOT FOUND : 3B7RF 222300 19980512 40m SSB
QSO NOT FOUND : 3B7RF 052500 19980512 20m CW
QSO NOT FOUND : 3B7RF 082200 19980511 17m CW
QSO NOT FOUND : 3B7RF 075700 19980511 15m CW
QSO NOT FOUND : 3B7RF 124400 19980509 12m SSB
QSO NOT FOUND : 3B7RF 094800 19980509 10m CW
QSO NOT FOUND : 3B7RF 164700 19980508 20m SSB
QSO NOT FOUND : 3B7RF 161600 19980508 12m CW
QSO NOT FOUND : 3B7RF 112400 19980508 15m SSB
QSO NOT FOUND : 3B7RF 152900 19980507 17m SSB
QSO NOT FOUND : 3B7RF 150100 19980507 10m SSB
QSO NOT FOUND : K7BV 054744 20130303 80m SSB
QSO NOT FOUND : K7BV 212437 20130302 20m SSB
QSO NOT FOUND : SV1QXU 221202 20130117 40m SSB
QSO updated : Call: KP4JRS Date: 20130727 Time: 233740 Band: 20m Mode: SSB
QSO updated : Call: TO7BC Date: 20120325 Time: 133100 Band: 10m Mode: SSB
QSO updated : Call: TO7BC Date: 20120404 Time: 192135 Band: 15m Mode: SSB
A functionality similar to the one in LOGic 9 would be great where you can limit the download to a single callsign.
I have not tried yet if I can correctly upload a log to EI7JZ if I change the LotW User ID in the Log4OM settings to OE6CLD, but set the Station ID to "Cork" (but I don't think so).
Any suggestions?
Claus, OE6CLD/EI7JZ
Re: LotW Upload With Different Account
Posted: 09 Sep 2013, 07:51
I think this issue cannot be fixed neither by creating 2 different profiles.
I'll check for LOTW protocol and i will add the "station" field.
Thanks for reporting
Daniele
Posted: 09 Sep 2013, 10:37
by OE6CLD
Mille grazie Daniele!
Just add the qso_owncall parameter to the HTTP GET.
qso_owncall call sign Returns only records whose "own" call sign matches.
You should be able to use an HTTP GET like this:
https://p1k.arrl.org/lotwuser/lotwrepor ... call=EI7JZ
