regarding new modes FT8 and T10, after import files from WSJT-x or JTDX
QSL Managment window, the RST sent and RST recvd are correct displayed.
When I open the Update QSO Window, the RST Sent and RST Rcvd are wrong just 599
If I update eg. QSL Infos and save it, then the correct RST eg. -00 will be overwritten with 599s and mess up the log.
vy 73 Hans DF2MC
FT8 and T10 RST in Update QSO Window wrong
Re: FT8 and T10 RST in Update QSO Window wrong
Dam it that is a bug!
I will ask Lele to look at that urgently
Thanks Terry !
I'll check, thanks for head up
Lele IW3HMH
Lele IW3HMH
Solved: FT8 and T10 RST in Update QSO Window
I have solved the problem,
just modify the RSTMode.csv, add the 2 new modes |FT8|T10 like:
PHONE>SSB|USB|LSB|AM|FM
CW>CW
JT>JT|ROS|FSQ|MSK|FT8|T10
DIGITAL>
Now it works !!
vy 73 de Hans DF2MC
CW>CW
DIGITAL>
Now it works !!
vy 73 de Hans DF2MC
I confirm.
this was pointed out in this thread, where the 2 files are both updated:
viewtopic.php?f=11&t=2917&p=16324&hilit=FT8#p16324
RSTMode.csv file is the configuration file that catches (start with) all modes (Log4OM modes) and define what is the right file to be loaded. If you miss the |FT configuration the file will fall back to DIGITAL (catch all) and then load the 599 default value.
Log4OM is completely driven by configuration files.
Hello FM,
I followed the instructions for FT8 but no luck ?
Info welcome.
73 - Rudi - ON7CL
Info welcome.
73 - Rudi - ON7CL
Did you download and install the files that I supplied here viewtopic.php?f=11&t=2917&hilit=FT8#p16324ON7CL wrote: 05 Aug 2017, 11:48 Hello FM,
Info welcome.
73 - Rudi - ON7CL
Also check if you have a ModeList_user.csv and RSTMode_user.csv files in your C:\Users\YOUR USER NAME\AppData\Roaming\LogOM FOLDER and if you have either delete them.
