In Layout dialog, save buttin is located at the first pane 'Column selection'. When user switches to 'Column layout' button is not available. this leads to confusion. It took some time until I figured out that I actually have to go back to the first pane, save changes and then exit. Otherwise, I loose all settings.
It would be much user friendly if save button is moved outside the first pane and set below both Tabs to be visible all the time Dialog is open.
Save button for QSO layout
Re: Save button for QSO layout
Thanks for the suggestion. I'll check that
