Hi, my query is about the log4om. Install the latest version and I find the difficulty of sending the qso confirmation through the QSL MENAGEMENT presenting an error, I have installed the tqsl well that if I can send without error, I have reviewed all settings and can not find the difficulty.
I have followed the instructions in the manual without success, the error is as follows.
INFO adif file created success fully
INFO TQSL Version 2.3.1
Executing TQSL with upload
Messages from lotw
TQSL version 2.3.1
Could not find the selected station location
Final state error in the command syntax (10)
Operation completed.
C: \ Program Files \ TrustedQSL \ tqsl.exe
C: \ Users \ Horacio \ AppData \ Roaming \ LogOM \ LOTW
I am waiting for the solution to wait.
Thank you very much
LU4DMX
Horacio Blasi.
LOG4Om
Re: LOG4Om
What this error is telling you is that you are not using the station location you have set in TQSL.
For example: Home, Cabin, Boat, motor home, etc.
Look in TQSL and set the station location to be exactly the same.
Re: LOG4Om
What Chuck is telling you is described in the TQSL Quickstart Guide (Rule 6) ..
6) Define a Station Location
Select TQSL's "Station Locations" tab and click the "Create a new Station
Location" button.
A sequence of "Add Station Location" dialogs will prompt you for the location
of the station used to make all of the QSOs in the log file you'll be
submitting, and will enable you to specify a name that identifies the Station
Location you've defined, e.g., "Home" or "Portable in EM29".
Re: LOG4Om
problem solved, thank you very much 73'dx. lu4dmx
