Can't Upload to LotW
Posted: 16 Mar 2018, 03:20
by W6SDM
I had to replace a hard drive recently and it caused me to have to re-install Log4OM. I have all of my QSOs replaced with ones from LotW. Before the crash, I was uploading QSOs without any problem. Now I get an error when I try to upload: Error: The selected station location could not be found. The box I have filled in on the "Log4OM Upload LotW" page under station location is "HOME".
I notice that the Log4OM program doesn't have a presence on %appdata% roaming with my new installation. It seems Log4Om didn't create it this time when I installed it.
Does anyone have any ideas?
Steve, W6SDM
Re: Can't Upload to LotW
Posted: 16 Mar 2018, 07:23
You wouldn't get the program to run if it had not created the LogOM folder and its contents
Did you install the TQSL software?
Posted: 16 Mar 2018, 16:38
by W6SDM
Yes, I did install TQSL. I realized when I just checked it that I hadn't installed a certificate on the new computer. I did complete that task but I am having the same problem, getting the same error.
Steve, W6SDM
Posted: 16 Mar 2018, 18:24
by DF5WW
Hi Steve,
did you have restored the Log4OM configs from your latest Backup ?
If yes it youd be possible that your TQSL Path is different. Have you
set the new path in Log4OM to the new installation of TQSL ?
Meanwhile i´ve changed my machine 3 times and always my uploads
to the different services working fine ... Could be only an error on the
"user" side ...
Posted: 16 Mar 2018, 18:30
by W6SDM
It's working now. The problem was that when I re-installed TQSL and the certificate, I didn't specify a location. Once I did that, everything worked.
Thanks for your help!
Steve, W6SDM
