Cluster-Filter "Phone" vs "FT8"
Posted: 22 Mar 2018, 08:30
by oe3ide
would be fine for version 2.0 if FT8 & JT65 Spots (..74 & ..76) would be excluded on cluster filter "Phone"
73 de Ernst
OE3IDE
http://www.oe3ide.com
Re: Cluster-Filter "Phone" vs "FT8"
Posted: 22 Mar 2018, 08:40
Edit your bandplan to list the agreed FT8 and JT65 frequencies as DATA then activating the Phone filter will exclude them
You will of course then miss any phone operator that is transmitting on the agreed data frequencies
Posted: 22 Mar 2018, 08:41
by oe3ide
Terry, thank you very much
73 de Ernst
Posted: 18 Jul 2018, 18:28
by oe3ide
it doesn't work for me.. maybe I missed something:
- cluster1.jpg (133.57 KiB) Viewed 12383 times
7074 should be recognized as "DIGITAL". See my bandplan.xml:
Code: Select all
<BandPlanRange>
<Band>40m</Band>
<Start>7000</Start>
<End>7030</End>
<BandUpperLimit>false</BandUpperLimit>
<EmissionType>CW</EmissionType>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7030</Start>
<End>7040</End>
<EmissionType>DIGITAL</EmissionType>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7040</Start>
<End>7073</End>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7073</Start>
<End>7076</End>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7077</Start>
<End>7300</End>
<BandUpperLimit>true</BandUpperLimit>
<EmissionType>PHONE</EmissionType>
<ModulationType>LSB</ModulationType>
</BandPlanRange>
Thanks for help
73 Ernst, OE3IDE
Posted: 19 Jul 2018, 15:53
by PE5TT
Why do you define DIGITAL 3 times ?
From 7030 to 7040, from 7040 to 7073 and from 7073 to 7076 !
Why not like this:
Code: Select all
<BandPlanRange>
<Band>40m</Band>
<Start>7000</Start>
<End>7030</End>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7030</Start>
<End>7077</End>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7077</Start>
<End>7300</End>
</BandPlanRange>
ps. i also changed 7076 to 7077 to create a gap less maping
Posted: 24 Jul 2018, 19:26
by oe3ide
i tried it with your cleaned 40m bandplan (bandplan_r3.xml)
Code: Select all
<BandPlanRange>
<Band>40m</Band>
<Start>7000</Start>
<End>7030</End>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7030</Start>
<End>7077</End>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7077</Start>
<End>7300</End>
</BandPlanRange>
But obviously it does'nt work for me as expected ...
- bandplan40m.jpg (154.33 KiB) Viewed 12290 times
Thanks & 73
Ernst
Posted: 28 Jul 2018, 10:27
by PE5TT
I don't know how it al is configured in Log4OM , it just seemt strange to me to define DATA 3 times.
And now i think that bandplan_r3.xml is for region 3, We in western europe live in region 1, so to me it seems you have to change bandplan_r1.xml
But again i am not a Log4OM expert.
Posted: 28 Jul 2018, 10:37
PG8M wrote: 28 Jul 2018, 10:27And now i think that bandplan_r3.xml is for region 3, We in western europe live in region 1, so to me it seems you have to change bandplan_r1.xm
Correct! Assuming the user enters the correct call sign, country and region in the Options\station info menu, when Log4om is opened it will use the regional bandplan for the region entered in the Station info tab.
Changing the region 3 bandplan will achieve nothing if your in another region unless you rename it to include _user.xml then Log4om will user this user defined file
Posted: 29 Jul 2018, 18:37
by oe3ide
Mea culpa!
I thought R1, R2, R3 are release versions ....
Will test it now with correct bandplan for region 1.
Thanks for quick help!!
73 de Ernst
OE3IDE
