Printing question
Posted: 22 Mar 2018, 20:10
by NZ4DX
Hi everyone,
I have looked in the manual but couldnt find anything on this. When I print my label it prints out in local time such as 5:00pm and not in UTC. How do i get it to print in UTC? thanks for the help
73 Fred NZ4DX
Re: Printing question
Posted: 22 Mar 2018, 21:18
by DF5WW
Hi Fred,
have you checked that your config has the real timezone ?
Posted: 23 Mar 2018, 02:20
by KI5IO
Fred,
Log4OM derives the time display for printing from your Windows OS. Just go to that particular setup and change as you see fit.
I just did the same with my laptop that I use for radio efforts.
I'm sure your PC local time is set OK and would be an automatic offset from GMT. The change from a 12 hour to 24 hour display is quite helpful.
I also use a routine to keep my computer clock synced to a standard mostly for when I work some digital.
Posted: 23 Mar 2018, 12:41
by NZ4DX
DF5WW wrote: 22 Mar 2018, 21:18 Hi Fred,
Thanks for the reply Juergen... where do i find that setting.. didnt see it anywhere in the options
Posted: 24 Mar 2018, 13:24
by NZ4DX
KI5IO wrote: 23 Mar 2018, 02:20 Fred,
Hi Nolan,
I tried switching the PC clock to 24 hour display and still having the same issue when i go to print a label
Posted: 24 Mar 2018, 15:02
NZ4DX wrote: 24 Mar 2018, 13:24
Hi Nolan,
It is definitely your Windows time setting that is wrong!
Right click on the time displayed at the bottom right hand corner of your windows desktop and select 'Adjust Date/Time'
At the bottom of the resulting window select 'Change date and time formats'
Set it up according to your local zone as below
Posted: 30 Mar 2018, 15:02
by NZ4DX
Thanks Terry... ONe last thing. when it prints it is showing right UTC now but is adding a PM with it.. How do i get rid of the PM ?
Thanks and 73
Fred NZ4DX
