New LoTW software
VA3AG
New LoTW software
Post by VA3AG »
Hi all! New LoTW TQSL 2.0 is available for download on the ARRL site. I downloaded it and installed and I can report that it is working just fine with Log4OM. :D
Aldo VA3AG
Re: New LoTW software
Be careful Aldo there are some issues with that which the LOTW user group are still working on, thats why I have not notified everyone.
VA3AG
Post by VA3AG »
G4POP wrote:Be careful Aldo there are some issues with that which the LOTW user group are still working on, tats why I have not notified everyone.
Thanks for the heads up Terry, It seems to be ok so far. this is RC7 and they also have a configuration update after you install.
I will report any problems as encountered.
Thanks again Terry.
Aldo VA3AG
MM0XXW
Post by MM0XXW »
VA3AG wrote:Hi all! New LoTW TQSL 2.0 is available for download on the ARRL site. I downloaded it and installed and I can report that it is working just fine with Log4OM. :D
Yep same here Aldo, no issues found at all and seems to be working (touching wood) quite effectively for me also :arrow: :)
Regards,
Martyn-MM0XXW
(MM1X in contests)
A new TQSL v2.0 out since yesterday. Can be downloaded at the LotW page. I´ve only downloaded but not tested yet.
Installed and tested. Don´t found any problems. Looks like working fine. :D ;)
G6VMR
Post by G6VMR »
Working All OK here also.
K0AY
Post by K0AY »
Well, my installation did not go so smoothly. I downloaded ver. 2.0 with no problems, but when I attempted to upload QSOs to LOTW, after creating the ADI file, LogOM hung up. The updated TQSL program was in a different location from the previous version. I had to go into settings in Log4OM and change the address of my TQSL. A few minutes of panic when I realized the great software I was using had a glitch, and it was something I did. But everything is fine now.
Art K0AY
I think that is a bit strange for the path to Tsql to change unless you originally installed it somewhere other than the default Tsql install directory?
K0AY wrote:Well, my installation did not go so smoothly. I downloaded ver. 2.0 with no problems, but when I attempted to upload QSOs to LOTW, after creating the ADI file, LogOM hung up. The updated TQSL program was in a different location from the previous version. I had to go into settings in Log4OM and change the address of my TQSL. A few minutes of panic when I realized the great software I was using had a glitch, and it was something I did. But everything is fine now.
Art K0AY
I will check the procedure that runs TQSL to see if there are issues when software is not found where it's expected.
Thanks for reporting
