PSK software
Posted: 03 Feb 2013, 14:01
by EI2GLB
Currently I am having to open HRD its logbook and DM780, then open Log4OM so i can use psk and get it to log into Log4OM,
Is there any plan to bring in some form of digi modes into the SW or a simpler intregration into another SW for digi modes.
Its a PITA having to open and close so many screens all the time. it would be ok it Log4OM could retain cat status while HRD is open.
Trevor
EI2GLB
Re: PSK software
Posted: 03 Feb 2013, 14:07
Trevor,
We already integrated FlDigi and your log gets automatically updated in LOG4OM as you work a station in FlDigi, see our user guide.
We plan to integrate MixW very soon.
Terry
Re: PSK software
Posted: 09 Oct 2013, 10:28
by MM0XXW
Sorry to hijack the thread, I just wanted to know if both programs (FLdigi & Log4OM) had to be running simultaneously in order for my digital contacts to be logged @ 4OM?
I think I know the answer but one does like to be doubly sure
Re: PSK software
Posted: 09 Oct 2013, 12:06
MM0XXW wrote:Sorry to hijack the thread, I just wanted to know if both programs (FLdigi & Log4OM) had to be running simultaneously in order for my digital contacts to be logged @ 4OM?
Hi Martyn,
Yes both programs need to be running for the FLDigi log to be read properly by Log4OM.
Re: PSK software
Posted: 09 Oct 2013, 18:15
by MM0XXW
G4POP wrote:MM0XXW wrote:Sorry to hijack the thread, I just wanted to know if both programs (FLdigi & Log4OM) had to be running simultaneously in order for my digital contacts to be logged @ 4OM?
Hi Martyn,
Kind of thought that to be the case Terry, just like to check these things though
Re: PSK software
Posted: 10 Oct 2013, 08:45
Well, log4om is also able to collect new QSO if started AFTER fldigi, by checking differences in the ADIF file generated by FlDIGI.
I'm currently integrating both systems a little bit more, to allow both systems to works together in a better way
Daniele
Re: PSK software
Posted: 10 Oct 2013, 10:30
IW3HMH wrote:Well, log4om is also able to collect new QSO if started AFTER fldigi, by checking differences in the ADIF file generated by FlDIGI
I tried that but it did not work as I expected!
I entered 4 QSO's in FLDigi without Log4OM running
Then I closed FLDigi and opened Log4OM and waited for some minutes to provide time for refresh.
Only one of the 4 QSO's was imported - The last one!
Re: PSK software
Posted: 14 Oct 2013, 08:35
Strange, i need to check that. Log4om take care of the changes from the latest row previously elaborated, so everything that comes after the last check will be imported at the next pass.
This is done because you can make more than one QSO in the time frame between two passes.
Checking that
Daniele
