Con V1.34.0.0 ho provato ad installare Omnirig 2 ma non funziona è normale?
Grazie dell'ottimo lavoro.
Giovanni.
Omnirig
Re: Omnirig
Giovanni,
OmniRig 2.0 is working fine here, although serving 1 rig only. Did you try to debug the communication using the OmniRig Client available at http://www.dxatlas.com/OmniRig/?
OmniRig 2.0 comes as replacement for a previously installed OmniRig exe file but does not register OmniRig as COM object. First install the original OmniRigSetup.exe, then replace C:\...\Afreet\OmniRig\OmniRig.exe by the OmniRig 2 exe as described in the OmniRig 2 readme.txt.
73, Markus HB9BRJ
73, Markus HB9BRJ
Re: Omnirig
Most importantly install to Run as an administrator
As as stated many times before both Log4om and Omnirig must be installed as above by following the instructions on page 1 of the Quick Start guide, page 9 of the user guide and in odour YouTube tutorials.
Re: Omnirig
Markus,HB9BRJ wrote: 18 Nov 2018, 16:17 Giovanni,
73, Markus HB9BRJ
Is OmniRig 2 working well for you?
I still get audio drops in my K3 (now and then) when Log4OM or WSJT-X is shutting down and OmniRig is the one common link.
73 - Nolan K. KI5IO
