How to change DX Cluster node
WA2SQQ
Post by WA2SQQ »
So last night I tried to use the forum search engine to determine how to change the DX Cluster I connect to.
Searched for “Change DX Cluster” & “DX Cluster”. Each time it tells me to be more specific as these are common terms. “The following words in your search query were ignored because they are too common words: cluster dx.” I hate to keep bothering Terry and the support crew, but I’m not sure how much more specific I can be.
Re: How to change DX Cluster node
That's the problem with this forum provider the search facility is a bit picky!
Go to the utilities drop down menu and select cluster
Click the disconnect button
Choose a new cluster from the drop down list where it says SERVER
Click connect button and once the cluster is connected close the cluster window
Typing 'Cluster server' into search on this forum finds loads of entries, its a case of trying different word combinations but it's not straightforward
