QSO Start Time ?
Posted: 01 Nov 2013, 17:12
by G4NVB
Would it be possible to include an option (in the current version or the new planned version) to enter the "QSO Start Time" automatically when you "Tab" out of the Callsign Field and enter the QSO "Finish Time" when the QSO is closed i.e entered into the database?
Re: QSO Start Time ?
Posted: 01 Nov 2013, 17:52
Hi?
Actually you have spotted a bug so I will move this post to the appropriate thread.
Something has changed because it was working as you request and I had not notice the problem, I will add it as a high priority issue to Mantis
TU
Posted: 01 Nov 2013, 18:21
by G4NVB
G4POP wrote:Hi?
TU
Hello Terry,
Thank you for your reply. Sorry about omitting my name, I thought My Signature was set up, it is now!
As I'm not that active at the moment I wasn't too sure how the Log4OM Time Stamp worked so did not realise it once worked the way I would like. Look forward to using Log4om a bit more in the future and also to future developments etc.
Posted: 03 Nov 2013, 16:10
by mm0kbt
I recently downloaded LOG4OM and noticed this was happening and have been using manual time selection most of the time which is a longer entry process. I didn't realise this was a bug! Looking forward to a fix coming out and looking forward to version 2 coming out too if version 1 is anything to go by!
Great software. Well done to all involved. :)
Davy
Posted: 16 Apr 2016, 14:54
by G4NVB
Is this issue still on the "To do list" ?
Posted: 16 Apr 2016, 16:21
G4NVB wrote:Is this issue still on the "To do list" ?
This issue is resolved
Posted: 16 Apr 2016, 16:51
by G4NVB
G4POP wrote:This issue is resolved
Hello Terry,
I've just installed Log4om (1.24.0.0) on my new Win 10 Laptop.
I typed in your callsign, it populated your name. I then "Tabbed" out of the callsign box but the start and end time are still incrementing in unison. Maybe I have a configuration issue.
Posted: 16 Apr 2016, 17:01
Hello Terry,
Please wait for the next release where it is fixed - I just tested it!!!!!!!!!!!!!!!!!!
Posted: 16 Apr 2016, 17:10
by G4NVB
G4POP wrote:Please wait for the next release where it is fixed - I just tested it!!!!!!!!!!!!!!!!!!
No problem Terry, just wanted to make sure it wasn't me ! !
Posted: 30 Apr 2016, 16:24
by G4NVB
Additional Information
For "SET Start Time when leaving the CALLSIGN Field" option to work you need to 'check' the box in "Settings / Options / Settings 2 / Misc"
