QSL Handling
g4nrt
QSL Handling
Post by g4nrt »
I am a reasonably recent convert to Log4OM and I absolutely love it! I am just starting two get into the QSL management area.
I have just received a BIG pile of QSL cards this week from my QSL manager. I can see how I can find and select each individual QSO and then change the "QSL Received" status but is there a way to do this in bulk - perhaps display a list of all my QSOs and pick the ones where I want to change the status to received with the same date and via Buro? It will take me ages to go through all of the cards - probably well over a hundred!
I would appreciate some guidance ...
Thanks for a brilliant programme and very 73,
David G4NRT/Z21NRT
Re: QSL Handling
Yes you can update in bulk but to make the list of QSO's more manageable its best to filter first, perhaps as follows:
In the QSL manager select 'Search parameters' at the bottom left of the window and search on
QSL received status = N
Mode=CW (Or mode of the bulk of the cards)
Please not screen grab is wrong it should be QSL Rcvd Status not sent :oops:
Having closed the 'Search parameters' window click the 'search' button at the top of the QSL manager window
Your now left with a list of CW QSO's where you have not received a card
Using the standard windows system of shift/click and Ctrl/click select the QSO's for update
Once selected set the QSL Received, QSL Rcvd by and QSL Rcvd date fields and click the save icon
Repeat process for other modes or perhaps you prefer to filter by DXCC etc the choices are infinite.
Watch the YouTube videos for more information
g4nrt
Re: QSL Handling
Post by g4nrt »
Terry. Thank you so much. That is excellent. I think the filters are the key ... I did actually think of another way (much less elegant!) which was to print the labels and manually cross out either "pse" or "tnx" QSL when I initial the card .....
73, David G4NRT
