In the filtered cluster window, a LOTW user was indicated by making the time red.
This is not the case anymore. (not sure when it happened, but may be after the last update?)
Is this a "local" issue or is a bug introduced?
73's, Evert PA2KW
LOTW User indication
Re: LOTW User indication
Just checked and it works fine, see image below, have you checked the options/QSL and Labels menu to ensure 'Show LOTW user' is checked
GM Terry,
Yes, option "Show LOTW user" was/is checked.
I restarted PC and software, but no positive result.
73's, Evert PA2KW
73's, Evert PA2KW
That's it ......
Thanks Terry
73's, Evert PA2KW
Thanks Terry
73's, Evert PA2KW
Always wise to update all data files after an updated install because on occasion the Master forgets to include them in the download
