Morning All
I would like the ability to order or remove colums from the cluster window same functionality as the other windows (Recent, POst Office and Archive etc).
Martin
Cluster Layout
Re: Cluster Layout
Hi Martin,
We already have that feature on our Mantis list but I doubt that it will be implemented before version 2.0
Re: Cluster Layout
Is there a visible Mantis list. Save duplication ?
Re: Cluster Layout
I have published this elsewhere but by now it is probably out of date so here is the Mantis list as of this morning - Item 196 refers to your suggestionG6VMR wrote:Thanks
Please note: Some planned new features are not listed
Ref. Summary
323 Incorrect beam heading and distance with Prefix/call stations
322 Log4OM makes an empy line when export qso`s to adif file.
321 Unable to update frequencies in Field to update
320 Qso lookup shows wrong dxcc enity
319 Incorrect Antenna information in QSO entry F2
316 IOTA 'New one' alert is not working correctly
315 Super Cluster F2
313 SFI/A/K index's not shown
311 Clublog and HRDLog upload errors not reported to user
310 Small cluster upgrade
309 TCP Control of PST Rotator seems stop working after several hours of idle
308 FlDigi (import from ADIF) issue
302 Colours for recent QSO's
301 One click close external programs
300 One click QSL recording
298 Handling LOTW duplicate entries
296 LOTW ADIF now includes award data
294 Latching option for voice keyer possibility
288 Membership list lookup reference
284 IOTA Alert filter revisions
283 Deficiencies in RSGB IOTA awards
282 Log4OM needs a User SCL
280 Support for Transverters
279 Add a link to download TQSL from the ARRL
278 Print start possition required
277 Add a LOTW alert feature to Log4OM
274 Locator in small cluster but missing from QSO input pane F1
273 Exception to filter list
272 Provide additional QSO input fields
271 Net control call sign search
269 SCL & Clublog Pop up window cluttered
265 Show awards credit status in cluster
264 QRZ lookup from Recent QSO's
262 ARRL Online DXCC submission
261 DXCC Summary Totals
254 Cluster spot lookup without QSY
251 Menu change
247 Default mode select for DIG_U and DIG_L (Omnirig & ICOM)
244 Save feature for Layouts
233 Awards-> Band/mode stats
231 Totals display for eQSL + LOTW + Cards
230 Date range filter for all awards
224 Unconfirmed QSO list
220 More Avery label templates required
219 Warning of unsuccessful LOTW or EQSL download
218 Worked / Not worked Panel in Qso information (F6) on top of all windows
214 Add more awards - List
212 Partial selection for update of status
210 Single click Vs Double click in "Qso information "(F6)
199 Column sort order in Country/Status grid is not persistant
197 F9 (Main Cluster) screen Persistence
196 User configuarable cluster screen (F9)
185 Progress indicator
175 Clublog & HRDLog upload of multiple QSO's required
140 Improvments DX Clusters F2/F9.
115 Provide a means to set fonts in windows
94 "Cancel" button needed for log import / export
87 Have all "label" functions within same window
78 List and delete for MySQL databases
58 Uniformity of spot selection by mouse click
20 Persistency of main window on start up
Re: Cluster Layout
Thanks for publishing the complete list of features/changes under consideration. I have an item I didn't recognize on here. When I open up the program and click on the cluster, the CW filter is the only one checked. I then click on SSB to add it, an those spots appear. Next time I open the program and select cluster, the filter is back to just CW. Can this be corrected? Is this somewhere in the list?
This is a great program. Thanks and Happy New Year.
Joe
WS2K
Joe
WS2K
Re: Cluster Layout
Joe,
Uncheck the CW box and then restart the program - Now all spots will show every time the program is opened.
Nothing checked = Show all spots
Re: Cluster Layout
spot filters are "shared" between different screens on program opening.
When you set a filter in a screen, this will be set as DEFAULT for the next program start (for the current run you can have completely different filters in different screens).
If the last screen you change is the one where you set the PHONE, this should be mantained.
I will investigate if, on closing, the closure of external cluster screen will make a forced save that will be set as default, because it's the last set saved.
Daniele
Daniele
Re: Cluster Layout
Hallo. Is possible to change colums of cluster windows in present ver 1.28 ?
Robert SP8SN
Robert SP8SN
73, Robert SP8SN
