Refresh Button
G6VMR
Refresh Button
Post by G6VMR »
From within the QSO Information window a click of the refresh button has no effect.
EG. I have uploaded to LoTW so the QSO have changed but the refresh does not pick this up. Removing the call and refreshing the data that way brings back the differences.
If Refresh is not supposed to work in this window my suggestion would be remove the option.
Martin
Re: Refresh Button
Martin,
Please post a screenshot of the window that you refer to
G6VMR
Re: Refresh Button
Post by G6VMR »
I will try but i need to get a windows keyboard. A MAC keyboard in use on my windows PC and I have not set up all the key functions EG screen print
Martin
Re: Refresh Button
If you use Windoze 7 check the snipping tool which does not require a Win keyboard
VK7XX
Re: Refresh Button
Post by VK7XX »
Another thing you can do is...... (with windows XP, other versions may be the same).....
go to START menu > all programs > accessories > accessibility > onscreen keyboard.
You will get a keyboard image on your screen which you can control with your mouse. The PRNT SCR (PSC) button is to the right of the F12 button.
John
G6VMR
Re: Refresh Button
Post by G6VMR »
Hi Thanks for the tips they work well.
Like snipping tool
Martin
G6VMR
Re: Refresh Button
Post by G6VMR »
Refresh does not work in this screen
Re: Refresh Button
Ah! Now I understand and yes while the call remains in the callsign field the data is held and you are correct this button is surplus to requirements I will speak to Daniele
Re: Refresh Button
Button has gone :)
G6VMR
Re: Refresh Button
Post by G6VMR »
Fast work :-)
