QSY off freq
HB9ETR
QSY off freq
Post by HB9ETR »
recently upgraded to v 1.37
noticed today that when double clicking to QSY, I don't end on the exact freq....ie, iso 14.031.000 I end up at 14.031.600. (and the .6 seems constant)
happens intermittently and on all bands//modes....with CLUSTER tab or with the list in the bottom rh corner.
not much of an inconvenience....but wasn't like this for me on the previous version.
Radio is a K3 with the the step setting to FINE....nothing changed with the K3.
Rob
HB9ETR / G0IFL
Win10 i5-11400 @ 2.60GHz
Re: QSY off freq
Rob,
I have been using 1.37 all morning with my Elecraft radio and o sign of offset issues it was exact every time I double clicked a spot in any of the cluster windows.
Are you sure that you have not set a transverter offset in the Log4OM settings and have you experimented with some of the special Elecraft choices as in the screen shot below. Try the delay choice for example
Re: QSY off freq
I must also add that an offset of 600 seems like a digi mode audio offset
HB9ETR
Re: QSY off freq
Post by HB9ETR »
I had the "special functions" selected.....not too sure if this "switched" when i installed 1.37 or previously done.
It appears to be ok now.
tnx, as always grateful for your input.
rob
Rob
HB9ETR / G0IFL
Re: QSY off freq
HB9ETR wrote: 01 Jun 2019, 15:16 I had the "special functions" selected.....not too sure if this "switched" when i installed 1.37 or previously done.
rob
Thanks for letting me know and I am pleased its resolved
