Yaesu FTDX-101D -Log4OM
F5VJC
Post by F5VJC »
Does Log4OM support this transceiver?
Re: Yaesu FTDX-101D -Log4OM
Although there is not a specific Omnirig rig profile for this radio I am sure it will work with the FTDX3000 or 5000 profile, you would have to try it.
Hello Dennis,
that means that Log4OM does not support any transceiver so it has no own CAT engine implemented.
Log4OM using Omnirig and/or Hamlib to connect via CAT. If any new TRX comes up the users have to
check Omnirig or Hamlib site to check for new rig files.
Will have the same problem in a few days when i receive the new Aerial51 ALT-512 SDR transceiver but
i know that is has full TS-2000 CAT support so the problem should be not a problem, HI.
F5VJC
Post by F5VJC »
Thanks, I tried FT-991 using Omnirig and it works!
73 F5VJC
Hi Dennis ... nice that it works ... ;) ;)
By the way ... we prefer Omnirig. 8-)
