FT4 Logging problem
Posted: 13 Aug 2019, 01:23
by W8QXR
I am not sure if my problem is a LoTW problem or a LOG4OM problem, so I will start here.
I am using WSJT, 2.1.0, JT Alert, 2.14.1 and LOG4OM, 138.0.0. When I log a FT4 contact into LOG4OM via JT Alert and then up load to LoTW, LoTW shows the contact as F4. When I download from LoTW to LOG4OM I get a message that the QSO is not found..…. MFSK.. If the contact is important to me, I will edit the contact mode to MFSK in LOG3OM and resubmit to LoTW and I will get the confirmation.
I would appreciate help solving this problem
Dave, W8QXR
Re: FT4 Logging problem
Posted: 13 Aug 2019, 05:46
The next release fixes this
Posted: 13 Aug 2019, 13:09
by W8QXR
Thank you Terry. Do you know when the next release is expected?
Dave, W8QXR
Posted: 13 Aug 2019, 13:41
A couple of days Dave.
Posted: 15 Aug 2019, 09:33
Posted: 18 Aug 2019, 18:10
by W8QXR
I downloaded the new version. I have used JTAlert in the past just to be able to log contacts to LOG4OM. I do not intend to use it once I figure out how to get WSJT-X to talk directly to LOG4OM. Please let me know which box to check on the Communicator inbound settings menu and what port number to use.
Also, do I need to make any changes to WSJT-X?
Dave, W8QXR
Posted: 18 Aug 2019, 18:31
W8QXR wrote: 18 Aug 2019, 18:10
Dave, W8QXR
Page 191 of the user guide?
Posted: 18 Aug 2019, 21:30
by N6VH
If you don't use JTAlert to log to Log4OM, then some of the JTAlert functions might not work - alerts, scan log, etc.
Posted: 19 Aug 2019, 00:39
by W8QXR
Thanks- works perfectly. I should have realized there would be a new User Guide.
Dave, W8QXR
