Hi All
If not already mentioned I would like the ability to set the default search limit number in the setting section. This would speed up refreshed rather than 5000 be the default. If you select 200 in post box and come out and go back to post box it reverts to 5000. Not sure of the way new LoTW found QSL add. Do they need to be in the active search number to update.
Martin
Search Limit
Re: Search Limit
I agree about the persistency of the display limit set and hopefully this will be changed soon.
All searches are on the complete logbook not the display limit
