Error with Omnirig
Posted: 02 Nov 2019, 12:55
I have a strange problem with Log4OM / HDSDR / Omnirig:
Win 10 Pro with all available fixes installed, Log4OM 1.40, HDSDR 2.80 beta 11, FT-950.
Log4OM and HDSDR will both work individually but not at the same time. If I start Log4OM first it works, but when I start HDSDR it says that Omnirig is not installed. If I start HDSDR first it works fine, but when I start Log4OM it pops up the Omnirig config window. The settings are all correct so I just click OK. There is no error message but Log4OM is not connected to the radio.
For testing purposes I installed two other programs that use Omnirig; CW Skimmer and Band Master. The story is the same; They all work fine individually and all three work at the same time without a problem. However if Log4OM is already running none of the other programs will connect, and if any of the other programs are already running Log4OM will not connect.
I found the following lines in the log during startup while HDSDR was already running:
2019-11-02 11:21:23.1730 INFO: OmniRigSinkClass: Omnirig status ONLINE for rig 1
2019-11-02 11:21:23.1740 ERROR: *** OmniRigManagement: Object reference not set to an instance of an object. ******* [Function: #=qLdfl8pHXY2ZTDhDrEND1OQ==] System.NullReferenceException: Object reference not set to an instance of an object.
at LogOM.BL.OmniRigManagement.#=qLdfl8pHXY2ZTDhDrEND1OQ==(Int32 #=q0b1vLO3j54mrPPC6bhEAEw==)
2019-11-02 11:21:23.3721 INFO: OmniRigManagement: OmniRig Started
It looks like it initially finds Omnirig but then loses it's reference to the object.
Any ideas appreciated.
73 Graham, M0VON
73 Graham, M0VON
