U.S. Bandplan revisited
K5CKS
Post by K5CKS »
I thought I had my bandplan file (bandplan_r1.xml) straightened out so that cluster spots would show up with the correct mode. This afternoon proved me wrong and I don't understand why at this point. The spot is for OU5U in Denmark on 7147.0. He is clearly inside the Extra Class Phone band but the Mode says "Digital". Here is my config for 40M.
<BandPlanRange>
<Band>40m</Band>
<Start>7000</Start>
<End>7040</End>
<BandUpperLimit>false</BandUpperLimit>
<EmissionType>CW</EmissionType>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7040</Start>
<End>7060</End>
<EmissionType>DIGITAL</EmissionType>
</BandPlanRange>
<BandPlanRange>
<Band>40m</Band>
<Start>7125</Start>
<End>7300</End>
<BandUpperLimit>true</BandUpperLimit>
<EmissionType>PHONE</EmissionType>
<ModulationType>LSB</ModulationType>
</BandPlanRange>
Thanks for the help!
Rory, K5CKS
Re: U.S. Bandplan revisited
Surely your in region 2?
K5CKS
Post by K5CKS »
I should be region 4 in the central part of the U.S. (Arkansas). Did I edit the wrong file??
Rory, K5CKS
You confusing IARU bandpla n regions with ITU/CQ regions you need to modify the band plan region 2 bandplan
K5CKS
Post by K5CKS »
I think I have it right this time, Thanks Terry!
Rory, K5CKS
