Log4OM V2 - JTDX - Omnirig
sq9jxb
Post by sq9jxb »
Welcome.
I installed Log4OM V2 and encountered a CAT error.
in Log4OM set CAT as Omnirig, in JTDX the same and the effect is such that in Log4OM CAT works properly and in JTDX there is no connection with Omnirig.
Omnirig version 1.19.
Regards
SGC PowerClear, EMU0202
73!
Jan SQ9JXB
Re: Log4OM V2 - JTDX - Omnirig
User guide
It is not necessary to run Version 2 as an administrator unless Omnirig or other associated programs (e.g. WSJT, JTALERT) are elevated for multithreading in which case Omnirig and all programs working with it should also be elevated (Run as an administrator).
So you need to install Log4om, Omnirig and JTDX to "Run as an administrator"
As an alternative, you can start Omnirig first, with admin privileges. That way it will share his communication ports to multiple applications.
sq9jxb
Post by sq9jxb »
Hello Danielle
Everything works as it should.
73!
Jan SQ9JXB
Great,
dovizenia dziekuje bardzo, i like a lot vodka from your area when i work in Warszawa:)
