Page 3 of 6
Re: Callsign look with WSJT-X
Posted: 18 Jan 2020, 08:34
by vk1hx
G4POP wrote: ↑18 Jan 2020, 08:18
vk1hx wrote: ↑18 Jan 2020, 08:08
Yeah I understand. However I'm not sure what other program would be using the 127.0.0.1:2333.
So are you saying just try different port numbers from 2333 for both JT and Log4OM UDP?
Yes choose a number that's not used by your other software and try it, nothing to lose
I've tried several combinations and restarted both WSJT-X and Log4OM V2 each time, still no go... surely this isn't that hard?
I am only using 2 programs (JT and Log4OM) I even took omnirig out of the equation and direct connection to the radio in WSJT-X, still no go.
Posted: 18 Jan 2020, 11:48
by vk7yum
Hi all
I have tried using different udp ports but that still hasn't worked, tried running everything as administrator - that didn't work; tried running individual programs (WSJT-X/Log4OM/Omnirig) as administrator - that didn't work. And before you ask, yes that was with a reboot between each setting "just in case".
In Log4OM, if I click Help -> Realtime Log and (just for fun) enter G4POP into the DX Call field of WSJT-X this is what appears in said log :
- log4omv2-rtl.jpg (155.8 KiB) Viewed 4068 times
It appears that data is coming through - just its wrong.
Oh and I have also uninstalled WSJT-X and reinstalled it (vers 2.1.2) and just for the fun of it vers 2.1.0 and both seem to be passing the same data ie I get similar messages in the realtime log.
And for a compete bit of fun, I installed WSJT-X (v2.1.2) and Log4OM on my laptop. Quite surprisingly it shows the same symptoms as the main computer.
Its really nice that it works for most people - just has me puzzled why it won't work on mine.
I have logged a support request so will await some feedback from that
Thank you for yor time.
Cheers
David
VK7YUM
Posted: 18 Jan 2020, 11:55
by vk7yum
Hi Phil,
Like VK7YUM I have tried everything to get he DX call field from WSJTx making it into Log4OM V2 Callsign field. I can see with David's settings, in the user guide the secondary UDP should be port: 2333 and the UDP Server port: 2237. David's are around the other way.
Not quite sure what you mean Phil - my settings are
exactly the same as in the manual ??
cheers
David
VK7YUM
Posted: 18 Jan 2020, 11:59
David,
I was caught out with WSJT because at first I had the same as you but suddenly realised that in WSJT the button marked Log does not actually log a QSO it just adds the call to a WSJT list.
The reason this caught me was because I had previously used WSJT live so when 73 was sent a box appears asking to save the QSO, I didn't realise that to actually log a QSO manually was if I recall Ctrl + Q
Is it possible you have fallen into the same trap for logging?
Posted: 18 Jan 2020, 12:08
by vk1hx
All good David,
My mistake, actually when WSJT-X installs the port settings are reversed. The UDP port is 2237 and the secondary UDP port is defaulted to 2333.
Phil - VK1HX
Posted: 18 Jan 2020, 12:09
by vk7yum
Hi Terry
Maybe
I'm not understanding the whole bit
If I put a call in WSJT-X in the DX Call field, click on generate std msgs, is whats supposed to happen that the Callsign field in Log4OM will populate with the call in WSJT-X ???
Logging is not the problem. If I click on log QSO or run through the sequence, exchange sig reports, send 73 then up pops the confirm log window and I confirm, then the qso is logged into Log4OM.
I was under the impression I did not have to log a call for log4om to get the data from wsjt-x.
Or am I way off mark expecting this data to be carried over without logging??
Cheers
David
Posted: 18 Jan 2020, 12:37
vk7yum wrote: ↑18 Jan 2020, 12:09
Hi Terry
Maybe
Correct
Your assumption is correct I assumed that your issue was logging because you referred to the ADIF message which is for logging a QSO not for call insertion of a call into the Log4OM interface.
The JTAlert message from port 2333 is not an ADIF format so the messages in the real time log are not connected to that.
Posted: 18 Jan 2020, 12:43
by vk7yum
Hi Terry
<Chunk deleted>
Ahh so what I am looking at is only confusing me even more
so back to the drawing board for me then
I shall "fiddle" some more ... 20 mins until I turn into a pumpkin
Cheers
David
VK7YUM
Posted: 18 Jan 2020, 13:28
by vk1hx
I thought we were trying to get the DX Call info from WSJT-X across to Log4OM in real time for lookup info? As shown in Terry's earlier post. Now the cluster has stopped working... works fine after a fresh install then next reboot nothing...
Posted: 18 Jan 2020, 13:53
by vk1hx
I give up. Here are my settings which are the same as everyone but for some reason I pick up the WSJT-X mode only.
