LOG4OM V2 & JTDX problem.
sq9jxb
Re: LOG4OM V2 & JTDX problem.
Post by sq9jxb »
G4POP wrote: 16 Jan 2020, 17:28
I just loaded and tested JTDX it requires a TCP port which we have not yet implemented - Soon!
TEMPORARY WORKAROUND
However I was able to log from JTDX to Log4OM V2 by using our ADIF inbound function, read the user guide about FLDigi ADIF use the same principle but direct path to the JTDX folder in AppData
Just logged a couple of QSO's without a problem using the above
Radio set up using Omnirig in JTDX just the same as WSJT
How to set Log4OM 2 and JTDX to make it work?
  If it is possible step by step.
Regards
SGC PowerClear, EMU0202
73!
Jan SQ9JXB
NN7D
Post by NN7D »
Instructions for logging from JTDX into Log4OM V2:
1. Log4OM V2 - open Program Configuration - ADIF Function tab.
2. Check Enable ADIF monitor
3. Click on folder icon and search for the wsjtx_log.adi file in the JTDX folder under User\<name>\App Data\Local\ folder. See below.
4. Click on the + tool.
5. Make sure you end up with the Enabled file path and file name as shown in the example below.
6. Click Save and apply at the top.
Note that the logging into V2 is not instant, as its a scheduled scan of the adif file. But it works fine for me.
Doug
W7DRM
sq9jxb
Post by sq9jxb »
Hello W7DRM
So I did and now Log4OM2 scans this .adi file for 20 minutes, and there are only 3900 QSO FT4 / FT8. The file has 2MB.
It takes long time.
I hope this works without a problem.
Regards
EDIT:
I did everything according to the description posted here on the Forum,
I did some QSOs and I don't write to Log4OM v2.
But I manage in a different way, the station sign appears in the Callsign window, the station details are completed, the rest I enter myself and log in after clicking the Save QSO icon.
Regards
73!
Jan SQ9JXB
Unfortunately JTDX doesn't provide UDP messages like WSJT-X
I'm able to get UDP messages through JTAlert using JT Alert adif udp broadcast (not related to specific Log4OM options, but available in JTAlert for JTDX)
SP2L
Post by SP2L »
Greetings Daniele et al.
This particular issue is a bit deeper than it look at first glance...
UDP protocol in JTDX is modified.
I think, getting in touch with Igor UA3DJY, JTDX team leader,
would be the best option in order to obtain detailed info.
Best regards.
Tom - SP2L
https://www.sp2l.eu
LU4FTA
Post by LU4FTA »
Thanks for the FLDIGI data, it works fine !! :) :) :)
BA5DX
Post by BA5DX »
sq9jxb wrote: 18 Jan 2020, 20:14
Regards
You can try JT_ Message replaces ADIF_ Message, log4om can automatically record logs from JTDX data. GL!
