Layout , info providers...
OD5ZZ
Post by OD5ZZ »
Hi
How can I get rid of the google map and replace it with a fixed worked before as it makes sense then a floating one and to be honest it does not make sense to have that google map as it adds nothing to my operation.
In Log4om v1 , when I type a partial call it will give the matched call signs , while in V2 even in the worked before window , only the exact call sign will be displayed.
On the statistics ( F1 ) , I can get the information but not the picture of the station displayed as a main picture at QRZ.com sometimes I can not get the info providers to work , it seems I lose the internet connection to connect to the external providers.
Any help please..??
Re: Layout , info providers...
You are only a QRZ ham member, you need to be a paying XML subscriber to get full information
Suggest you sign up for HAMQTH and use that, it's free
As for changing the map you cant
OD5ZZ
Post by OD5ZZ »
hopefully it will be an option to choose the layout you feel it is best for your operation in future releases
Could be an option, assumed we cannot, even with our maximum committment, satisfy every layout desire :)
OD5ZZ
Post by OD5ZZ »
Thanks a lot , The Worked before ( F10 ) is now a TAB and all issues fixed
NN7D
Post by NN7D »
Correct! :D
