Log4OM2.0 "Recent qso" not working
Re: Log4OM2.0 "Recent qso" not working
Log2 database.SQLite is under users\Ed\My Documents
SQLite.interop.dll is under ...My documents\Log4OM2_2_7_0_0_portable\portable\x86
I thought maybe the 5000 entry limit in log entries could be the problem, but changing it did not seem to make any difference, even after rebooting. Why is it listed under portable? I thought I always downloaded the regular version, not the portable version.
Thanks for continued help. The program has made it really fun to operate! 73
My guess is you have two installations the original plus a portable version that you recently downloaded
I reloaded the most recent log4om2 and it refreshed the first time I used it. Then it stopped refreshing and adding my contacts. How can I remove "extraneous" copies of the program, if they exist, without losing my database? I also disabled my virus software and still had the same problem. 73 and thanks
I made a new database which works fine. But using that database I cannot check for worked before stations. Is there a way for the program to check two databases?
Just import one of your backup files into the new database
I was wrong. It worked for three qsos, and then no longer "refreshed" new qsos into the log. I still need help. What about going to a previous log4om2 version? Should I delete the current file and load an older one? I have re-downloaded the current, newest file since this problem began. Each time it works for the first few contacts, then refuses to "refresh". Thanks for your help! 73
