Page 1 of 2
Log4OM+JTDX+CAT.
Posted: 19 Jan 2020, 04:49
by va3vf
Is it possible to have the CAT active with both Log4OM and JTDX at the same time?
I tried with with Omnirig, but it did not work, only one at a time works.
Thanks.
Re: Log4OM+JTDX+CAT.
Posted: 19 Jan 2020, 08:37
You need to run all three programs as an administrator
Posted: 19 Jan 2020, 19:57
by va3vf
G4POP wrote: 19 Jan 2020, 08:37
They were/are configured to run as admin, but only one works at a time, either Log4OM or JTDX but not both at the same time.
Posted: 19 Jan 2020, 20:03
by VA3AG
va3vf wrote: 19 Jan 2020, 19:57
Connect JTDX to the radio first (It needs to control the frequency for it to work)
Posted: 19 Jan 2020, 20:59
by va3vf
VA3AG wrote: 19 Jan 2020, 20:03
Still won't work when I try to activate CAT in Log4OM with JTDX already running with CAT active.
I always thought that only one application at a time can have CAT control.
Not a problem, JTDX CAT control only is enough.
Posted: 20 Jan 2020, 00:12
by NN7D
va3vf wrote: 19 Jan 2020, 20:59
Normally yes. But CAT control via OmniRig is multithreaded, meaning any program which uses the OmniRig app for CAT can share 2-way CAT control at the same time. I am running Log4OM V2, BandMaster, JTDX and WSJTx all with CAT and working. But all have to be started with Admin privileges.
Doug
W7DRM
Posted: 21 Jan 2020, 13:00
by va3vf
W7DRM wrote: 20 Jan 2020, 00:12
Hi Doug,
Still not working. Does it make any difference if OmniRig was already installed prior to Log4OM installation? I see that OmniRig installation is an option when installing Log4OM. I was wondering if there is an association missing, since I did not check that box.
73 de Vince
Posted: 21 Jan 2020, 13:04
Sounds like an old version of Omnirig check out the Omnirig site but I think latest is 1.19
Posted: 21 Jan 2020, 13:13
by va3vf
G4POP wrote: 21 Jan 2020, 13:04
Right you are. I thought I had the latest version. Not sure how I missed that. Installing version 1.19 now.
Thanks,
Vince
Posted: 21 Jan 2020, 13:37
by va3vf
va3vf wrote: 21 Jan 2020, 13:13
Still no go, but that's OK.
73 de Vince
