I was running with the original version 2.0.0.0 since it was released.
However only through reading this board did I discover by accident that there has been a version 2.0.1.0 and 2.1.0.0 released since.
I had the "Check for updates" and "Send Statistics" both checked in the Program settings.
I have opened and closed the program numerous times but was not advised of the new releases/updates?
Anyone else have this problem or is there something I am missing?
73 Steve VK7CW
"Check for Updates" - not working
Re: "Check for Updates" - not working
Steve,
Did you not have a Yellow Triangle on the Main UI? Left clicking on that triangle will show you updates and data files that have been updated (IE: SOTA, IOTA, etc.)
Check out Users Guide on Page 30 as well.
Good point, and I am not sure.Did you not have a Yellow Triangle on the Main UI?
I will check on the next update.
Last version you would get a popup box when the program started telling you that there was an update, which was much easier than looking for a yellow triangle.
KI5IO, thanks for the reply.
73 Steve VK7CW
