Send Spot is using TX freq. in split mode
dl1clm
Post by dl1clm »
Hi All,
I use the 'Send Spot' icon on the main UI and it is working fine when I am in simplex mode.
When I Send a Spot while my tranceiver (IC7300 via Omnirig) is in split mode, the cluster spot is showing my TX freq.
That means the station I spot is on 14.020 and listening '2 up' my TX freq is 14.022 now my spot entry in the cluster is showing that station is on 14.022
I looked in the manual to see if I have to change a setting but could not find it.
In version 1 my cluster spots showed my RX freq.
I'm not sure if this is a bug or if it's a deliberate choice to send the tx frequency.
73 Dick DL1CLM
Optibeam OB 9-5
Re: Send Spot is using TX freq. in split mode
Hi Dick,
It's a bug, i'll fix it. Thanks
Daniele IW3HMH
Fixed in 2.2.0.0
dl1clm
Post by dl1clm »
Many thanks, Daniele !
Optibeam OB 9-5
