Hi
Need some help here.
First time trying to upload to LoTW using QSL Manager. Getting an error saying "Creating folder cannot create........" see attached for full error pls.
73 Ras VK2QV
V2 LoTW QSL upload issue
- log40mv2_lotw err.PNG (10.01 KiB) Viewed 4277 times
Re: V2 LoTW QSL upload issue
Hi Ras,
do you have a temp. path configured in External Services --> LOTW ? If not do so and try again.
Roland
Roland
Flex 6600 - Spiderbeam
Roland,
This is interesting. I've not tested without a Temporary path being specified but on page 71 of the User Manual it says a Temporary path MUST be specified. However, in the window where you would define this path it shows as optional (opt). Is this a documentation error or does the window need to be corrected?
73 - Tom NS8K
Hi Tom,
yes you are correct, documentation info vs. actual config window are not aligned (yet). It was not working for me without temp path.
Roland
Roland
Thank you Roland. Set the temp path. All working fine now. 73 Ras de VK2QVHB9VQQ wrote: 30 Jan 2020, 13:30 Hi Ras,
Roland
Thanks for the feedback, glad it is working now. Guess documentation needs some updating.
Can someone tell me where I can find the temp path file?
Mike-W2MJP
Mike-W2MJP
Thank you for the reply Terry, And a BIG Thank you to Doug W7DRM who has been there to answer a few questions for me. V2 is up and running in my shack. A big change from V1 which was also very good. Nice job and congrats to the Log4om team. Keep up the great work.
Mike-W2MJP
Mike-W2MJP
