Error on import ADIF from N1MM contest
ec5w
Post by ec5w »
Hello.
I have problem on import from n1mm ADIF file to log4omv2, attached log of problem. Same file imports perfect on log4om v1.
The import start but after only 110 entries stops, the log have 760 contacts. Also say saved to database and any is saved.
18:21:36: Callsign: LZ1MC Date: 01/01/2020 10:57:00 Band: 40m Mode: RTTY DXCC has changed from 0 to 212
18:21:36: Callsign: 9A9TT Date: 01/01/2020 10:57:46 Band: 40m Mode: RTTY DXCC has changed from 0 to 497
18:21:36: Callsign: OH3P Date: 01/01/2020 10:58:08 Band: 40m Mode: RTTY DXCC has changed from 0 to 224
18:21:36: Callsign: G0GDA Date: 01/01/2020 10:59:12 Band: 40m Mode: RTTY DXCC has changed from 0 to 223
18:21:36: SEARCHING AWARDS REFERENCES...
18:21:44: End of ADIF import <-- STOPS ON 110 CONTACTS, LOG HAVE 760 CONTACTS !!!!
18:21:44: Begin LOG save
18:21:44: constraint failed UNIQUE constraint failed: Log.qsodate, Log.callsign, Log.band, Log.mode Callsign: GW0A Date: 01/01/2020 8:15:47 Mode: RTTY Band: 80m <-- START INSERT ON DATABASE WITH ERROR !!
18:21:44: constraint failed UNIQUE constraint failed: Log.qsodate, Log.callsign, Log.band, Log.mode Callsign: F5GFA Date: 01/01/2020 8:20:42 Mode: RTTY Band: 80m
18:21:44: constraint failed UNIQUE constraint failed: Log.qsodate, Log.callsign, Log.band, Log.mode Callsign: EA4BAS Date: 01/01/2020 8:25:12 Mode: RTTY Band: 80m
18:21:44: constraint failed UNIQUE constraint failed: Log.qsodate, Log.callsign, Log.band, Log.mode Callsign: DQ9Y Date: 01/01/2020 8:27:38 Mode: RTTY Band: 80m
18:21:44: constraint failed UNIQUE constraint failed: Log.qsodate, Log.callsign, Log.band, Log.mode Callsign: GW5NF Date: 01/01/2020 8:32:21 Mode: RTTY Band: 80m
18:21:47: constraint failed UNIQUE constraint failed: Log.qsodate, Log.callsign, Log.band, Log.mode Callsign: OH3P Date: 01/01/2020 10:58:08 Mode: RTTY Band: 40m
18:21:47: constraint failed UNIQUE constraint failed: Log.qsodate, Log.callsign, Log.band, Log.mode Callsign: G0GDA Date: 01/01/2020 10:59:12 Mode: RTTY Band: 40m
18:21:47: LOG saved <- DON'T SAVE ANY LOG TO DATABASE
18:21:47: Save completed
log4om2 n1mm.txt
(29.44 KiB) Downloaded 251 times
HB9VQQ
Re: Error on import ADIF from N1MM contest
Post by HB9VQQ »
Ola Miguel,
if you send me your ADIF file I can have a look. You'll find my email on qrz.com. or you can send me a PM.
Roland
Flex 6600 - Spiderbeam
