I'm using a K3 with Log4OM V2. I've recorded a Voice Keyer message as per the LOG4OMNG manual. Using the CTRL F1 on the PC keyboard sends the message perfectly including activating the K3 PTT. The levels are fine and the AUDIO box appears on the status bar of Log4OM as expected. After the message has finished, the AUDIO status box disappears from Log4OM but the PTT remains set. I have to press the assigned PTT button on the PC keyboard to drop back to RX.
Can Log4OM be configured to drop the PTT after the message has been played or is this intended?
Mike
G0KAD
Voice Keyer PTT
Re: Voice Keyer PTT
Hi Mike,
have linked this post to A-Team. Don´t work with VC and don´t have a K3 but stay tuned.
Re: Voice Keyer PTT
I had posted this about 3 or 4 days ago.
Same with my Flex 6600. MOX stays keyed.
Re: Voice Keyer PTT
I've found a possible glitch. Fixing and testing it.
Thanks for reporting
Re: Voice Keyer PTT
With 2.3 I am unable to make this to work at all Does not send audio or Key TX.
I am going to keep messing with it.
