Ver 2.0 Propagation Reliability
K5CKS
Post by K5CKS »
I think the Propagation Reliability is a fantastic addition but I have noticed some problems with it. On 15M this morning HU1DL in El Salvadore shows 88 reliability in the cluster. If I open the Propagation tab and generate a Reliability map for 15M the reliability appears to be zero in South America. Should these two be the same?
Thanks,
Rory, K5CKS
WA2SQQ
Re: Ver 2.0 Propagation Reliability
Post by WA2SQQ »
The on line version allows you to select different antennas. I believe V2 uses a default "dipole", with no other options. That will surely skew the predictions
