If possible in the future it would be nice if the band map would retain the settings.
I currently don't use it much because I have to set the zoom and position every time I go back in. Version 1 was much more usable for me although I can see the potential for improvement in V2.
But zoom, centered on frequency and remembering the filters would make it much nicer.
Also follow the band when you switch bands.
kd0zv
Bandmap
Re: Bandmap
I find the Band Map to be totally unusable. This is a snapshot of the CW end of 20m this afternoon. My suggestion is there is too much line spacing between spots, and the lines go both up and down from a single frequency. I also probably also needs another couple of greater levels of zoom. I also agree on the need to follow the rigs frequency.
73 Peter G3ZSS
