Seems if Band is set to 60m (visible in log), when "edit qso" is opened, it opens with "band" as nothing.... so when you save it, it saves back to the list as no band. I assume there is some kind of checking going on that is tossing it out? Even though 5.357ish is of course 60M.
Only occurs on the "edit qso" screen (at least from the QSO manager page) so far in testing.... update info (pulling from QRZ) doesnt seem to change it, or anything else I've done thus far.
v 2.3.0.0
60M
Re: 60M
I can confirm there is no band after opening a 60m QSO.
Everything seems to be normal beyond that as you can search for contacts in statistics and 60 meters shows.
