Distance running in the 2.3.0.0 Version
IW3GCR
Post by IW3GCR »
The km distance is'nt display in recent qso's window ( F7),while is present in main window(F6).
73 Nicola
Nicola IW3GCR
Re: Distance running in the 2.3.0.0 Version
See how to display different columns layout in the user guide
IW3GCR
Post by IW3GCR »
Thanks for your prompt reply ,the
problem is'nt different layout ,the display columns Is already selected,but the value of the km inside is always 0.
73 Nicola
Nicola IW3GCR
IW3GCR wrote: 07 Feb 2020, 17:34 Thanks for your prompt reply ,the
73 Nicola
Then you either have not entered your locator in station info part of config
Or
Your not having a locator in the input QSO fields section of main UI
IW3GCR
Post by IW3GCR »
Please....
don't ask me to check the fuses now.
Nicola IW3GCR
IW3GCR wrote: 07 Feb 2020, 17:44 Please....
OK message received and understood!
Amazing !
The first option to check something is in users hands. The team members and/or other users can try to give
some help to find out where the problem is. What Terry wrote are the most mistakes that users did and that´s
missing locator in the own settings or missing locator at the lookup or from WSJT-X/JTDX.
What we cannot do is clairvoyance and we do not have crystal balls for fortunetellers.
If someone tries to help you can also react a little bit more friendly.
What we do is our passion in our freetime. We are not payed supporters
as you may find for commercial logbook software.
IW3GCR
Post by IW3GCR »
It was not in my intentions to offend or denigrate anyone especially for your passion that I share with you, otherwise we will not be here to waste time, trying to solve all the various problems of the V2 version, which conquered me immediately, making me abandon the already very tested version V1.
73 Nicola
Nicola IW3GCR
