i have som problem at open the zip file sayes that it is arkive file and in enny zip pogram
vy 73 de oz0hf
open the zip file on the new version
Re: open the zip file on the new version
Did you have a software like WinZIP, WinRAR or 7zip installed on your computer ?
If not you must download and install. Then you have to unpacking the archive file
with right mouseklick and unpack to Log4OMNG or however is named. Best is to
unpack to the desktop so the file can be deleted after installing V2 ...
TNX for info
Problem is now ok i moved the zil file to a new map and started on that so all ok now
vy 73 de oz0hf
vy 73 de oz0hf
