Circuit reliability vs. cluster reported Reliability
KA4CDN
Post by KA4CDN »
Shouldn't the value displayed in the Cluster (F8) Reliability column match the data displayed on the Progration (F9) -> Circuit reliability graph? Perhaps I am misunderstanding something.
Re: Circuit reliability vs. cluster reported Reliability
KA4CDN wrote: 13 Feb 2020, 15:05 Shouldn't the value displayed in the Cluster (F8) Reliability column match the data displayed on the Progration (F9) -> Circuit reliability graph?
Did you ever figure this out?
va3vf
Post by va3vf »
Curious as well. Something does not look right.
I'm 100% FT8 these days, so I changed required SNR to 25%. The predictions do not seem to match. I know it's a propagation based prediction, aka, black magic. ;)
ac5aa
Post by ac5aa »
Also seeing the same problem. Is it that one or both calculations are not doing UTC offset correctly? Haven't had time to look into that further.
73, Duane AC5AA
Cluster propagation is calculated hourly on 4 digit locators for the entire world.
4 digit locators are pretty wide in area, and cluster location is always calculated on country centre.
Callsign focused propagation is calculated in realtime (but should not differ, as voacap take into account hour, minutes) focused on 6 digit station locator.
Propagation cannot be calculated in realtime on all spots, instead we calculate propagation in background for all gridsquares then we will apply data near the spot.
For that reason, the voacap values may sometime differs.
Knowing that, if you have evidence of strange values i'll be glad to check.
dl1clm
Post by dl1clm »
I'm a little confused because I've been seeing exactly the same Circuit Reliability diagram for over 2 weeks when I give up the call PJ2LS.
Since today I have a different Circuit Reliability diagram.
I had the impression that the VOACAP information used for the Circuit Reliability diagram is only updated once a month.
Dick DL1CLM
Optibeam OB 9-5
voacap IS working based on year/month/sun spots and mutual position.
There are not other parameters taken into account in the voacap engine.
Edit: It's not our choice, it's how VOACAP calculation works :)
dl1clm
Post by dl1clm »
So it is correct that the Circuit Relaibility diagram in the cluster does not change during 1 month.
Optibeam OB 9-5
Yes, unless there are changes in sunspots.
dl1clm
Post by dl1clm »
Thanks Daniele
Optibeam OB 9-5
