Missing ic-7300 in Hamlib and Omnirig
oz4abi
Post by oz4abi »
Hi
I have just started using WSJT-X, but I can't find my ICOM IC-7300 in either Hamlib or Omnirig. What am I doing wrong?
Re: Missing ic-7300 in Hamlib and Omnirig
If you´re using WSJT-X or JTDX and if you´re using Omnirig you have set WSJT-X/JTDX to Omnirig Rig 1. Not to
you´re Transceiver. In Omnirig himself you can setting up youre transceiver but you have to open Omnirig at
the first time without connected to any logging software or transceiver. If you do so you can define in Omnirig
for Rig 1 the needed COM, Speed and all the other things. Don´t can tell you something about Hamlib so never
have used it. We prefer Omnirig.
NN7D
Post by NN7D »
OM,
Using OmniRig (make sure you have the latest OmniRig version and latest rig ini file downloaded), there are 2 IC-7300 files to choose from.
Example:
Doug
W7DRM
