2 call signs in same log file
Posted: 20 Feb 2020, 13:17
by Ki4P
Good morning
i changed my call last year,
is there a way, if you have two call signs in one log to note on lookup when you click on a station in the cluster window to denote what call you worked that station with? i know if you click on each qso in the worked previously window you can get it that way but was wondering if there is a way to get it on the initial worked before window. just some little something to show worked under a specific call, or maybe set a date timeline or some way, like i know when i started using new call. just want to cut down on so many mouse clicks and windows.
Thanks!
Richard
Re: 2 call signs in same log file
Posted: 20 Feb 2020, 13:27
Not in the cluster, best way is to have the floating WB4 window open at the same time with the 'Station callsign' column showing.
Then as you click a cluster spot the WB4 status will display QSO'S and what call you were using for the contact.
Posted: 20 Feb 2020, 17:01
by Ki4P
Thanks, I'll try that if I can find it, haven't seen anything like that yet! Good upgrade from Ver. 1
