Log4OM 2.3 - JTDX 2.1.0-148 - without JT-Alert
Posted: 22 Feb 2020, 09:27
by sq9jxb
In such a configuration as in the pictures, everything works without any problems so far.
QSO login and clearing the callsign window after logging in.
Image Image
I hope you won't get anything wrong with the program.
Re: Log4OM 2.3 - JTDX 2.1.0-148 - without JT-Alert
Posted: 22 Feb 2020, 09:54
sq9jxb wrote: 22 Feb 2020, 09:27 Hello
Image Image
When using this configuration do not use ADIF monitor or there is a risk of duplicates
I will re-write the user manual to reflect this change in JTDX in due course
Jan thank you for saving me time by researching this
Posted: 22 Feb 2020, 10:27
by sq9jxb
Hello Terry
ADIF Monitor is inactive because it has already made duplicate log entries for me.
It tired me that there was no full communication between JTDX and Log4OM 2.3 and it worked.
And one more thing - what JTDX decodes is displayed in the Realtime log.
Regards
Posted: 22 Feb 2020, 10:40
by SQ5TDZ
I have been testing since yesterday with these settings and for now I have no duplicates, I did not use jtalert
Posted: 22 Feb 2020, 10:59
by sq9jxb
Andrzej
ADIF Monitor masz włączony czy wyłączony?
U mnie duplikaty były przy włączonym. W konfiguracji którą mamy nie będzie duplikatów. ADIF Monitor wyłączony.
ADIF Monitor on or off?
I had duplicates on. In the configuration we have there will be no duplicates. ADIF Monitor is off
Posted: 22 Feb 2020, 11:04
by SQ5TDZ
sq9jxb wrote: 22 Feb 2020, 10:59 Andrzej
Janku adif monitor is on because I use fldigi, disable cat in log4om and log in this way qso from fldigi to log4om
Posted: 22 Feb 2020, 12:08
by sq9jxb
Andrew
I don't use FL Digi, I don't have patience with this program. I have a different set of programs for other broadcasts. :)
Andrzej
Ja FL Digi nie używam, nie mam cierpliwości do tego programu. Dla innych emisji mam inny zestaw programów. :)
Posted: 22 Feb 2020, 16:28
User guide updated and ready for download by users
Integration of latest JTDX checked and found to work 100%
