Rovers using callsign/R are logging as Russia #54
Posted: 23 Feb 2020, 15:33
by n5tm
If working a "rover" station in a VHF contest you log the callsign/R the software is logging the station as being in Russian, not the US. Is there a work around?
Re: Rovers using callsign/R are logging as Russia #54
Posted: 23 Feb 2020, 15:57
There is no such suffix as /R its the same as /QRP not a legal suffix so it's interpreted as a country identified and R = Russia
Check your licence conditions you won't find /R
Posted: 23 Feb 2020, 16:06
by DF5WW
The same questions always coming up on a lighthouse weekend. Some stations using /LH which will interpreted
as Norway from each logger which uses ADIF standards. Real extensions are only /P, /M, /MM and /AM. If i work
stations with extensions like /LH, /QRP, or some other´s i don´t log it. I only log the call without it and all is
fine.
That´s the only "workaround" for this ;) ;)
