Error(s) using JTDX/JTAlert/Log4OM2
Posted: 25 Feb 2020, 20:31
Trying Omnirig with IC-7300-Data + IC-9700-Data now, on both frequency is not correct, being on 5357 (60M-FT8 jumps to 5357,055 at startup
), also op 144.174 the frequency jumps to 144.174,055
Another problem: with the same JTDX settings between the IC-7300 & IC-9700 there is a huge TX-delay with the IC-9700: about 8 seconds !!!
I'am sure I'am not the only JTDX/JTAlert/Log4OM2 user with a IC-7300 + IC-9700, so any help from other users with the same setup will be appreciated!
Yes I'am using the latest JTDX & JTAlert versions, using v.2.2.0.0 of Log4OM2 because of the QRZ lookup error in v.2.3.0.0
73 de Frank PH2M
73 de Frank PH2M
