LOTW qsl status "Validated" not available in V2
dl1clm
Post by dl1clm »
Hi All,
I have seen that in V2 there is no LOTW qsl status "Validated" and that during the Adif import from V1 all QSO's with LOTW QSL status "Validated" are changed to QSL status "Yes".
This has major consequences for the upload to Clublog because after a complete upload, only QSOs with "Confirmed" and "Worked" are shown there. All QSO's that had the status "Validated" in V1 are now displayed as "Confirmed" in Clublog.
Clublog normally displays the status "Validated" as "Verified".
V1 LOTW status .jpg (56.31 KiB) Viewed 3057 times
V1 QSL status FT5ZM.jpg (67.17 KiB) Viewed 3057 times
The same QSO with FT5ZM in V2
V2 QSL status FT5ZM.jpg (42.55 KiB) Viewed 3057 times
73 Dick DL1CLM
Optibeam OB 9-5
dl1clm
Re: LOTW qsl status "Validated" not available in V2
Post by dl1clm »
Some additional info:
that's what it looks like on the DXCC charts in club logs.
After the upload from V2 all blue "V" were changed to green "C".
Clublog DXCC Charts.jpg (87.47 KiB) Viewed 3055 times
I hope this can be resolved very soon.
73 DIck DL1CLM
Optibeam OB 9-5
Hi Dick
Log4OM works with ADIF 3.10 specifications. Those specifications removes the "VALIDATED" concept from the QSL confirmation.
According to that, Log4OM will IMPORT validated value for QSL and save it as "CONFIRMED" as per specifications.
Choice was made probably because they finally understood that a qsl card received can be used to "validate" a big number of awards, not only the ARRL DXCC.
QSL management is intended to manage the status of the requested/sent confirmation.
Status of a reference gained with the QSL is mantained in the references environment of Log4OM, that is integrated but different from confirmation environment.
Based on your screen it seems Clublog is still (as many other does) working with "validated" concept in the QSL received status.
I will check what i can do, eventually, to produce an "old" format for clublog needs mixing up dxcc confirmation status with the qsl received status.
dl1clm
Post by dl1clm »
Hi Daniele,
Thanks for your quick response.
It might be a solution to first run an SQL query in QSO Manager before sending an adif file to clublog.
This query can then change value from <LOTW_QSL_RCVD:1>Y to <LOTW_QSL_RCVD:1>V .
Every LOTW confirmation received has the status Verified (Validated), so changing all Y to a V solves the problem.
or is that a bad solution (work around)?
Dick DL1CLM
Optibeam OB 9-5
