UDP INBOUND MESSAGES
Posted: 10 Mar 2020, 12:20
by G4YBI
I've previously set up my ic-7300 with V2 via omnirig and WSJTX and JTALERT, all running and logging fine..
I'm now trying to set up my ic-9700 on a different laptop using windows 10 with V2 via omnirig and WSJTX and JTALERT, the problem I'm having is inserting the correct message in the UDP box,
I select port 3 and ADIF MESSAGE, and then type the inbound message,
[UDP_INBOUND] [ADIF_MESSAGE] [2235] JTALERT QSO but when you add the message to the UDP message box it now reads,
[UDP_INBOUND] [ADIF_MESSAGE] [3] [UDP_INBOUND] [ADIF_MESSAGE] [2235] JTALERT QSO
it does the same with the Rebroadcast message as well, I've tried it with version V2,2.2 / 2.3 / 2.4 only thing I've not tried is uninstalling and reinstalling LOG4OMV2 am I missing something here......
Many thanks for any help, Paul G4YBI
Re: UDP INBOUND MESSAGES
Posted: 10 Mar 2020, 13:55
Er! Why port 3? That sounds more like a com port than a UDP port
Just set up v2 as detailed in the latest user guide for JTALER/WSJT
Set up the 9700 on the other Omnirig rig
Ensure that the correct sound devices and Omnirig rig numbers are selected in WSJT/JTALERT
Posted: 10 Mar 2020, 15:10
by G4YBI
Yes that's right the 3 is for the com port, the middle box for the UDP message, and the end box is where you select ADIF message,
the problem I have is when I type in the message [UDP_INBOUND] [ADIF_MESSAGE] [2235] JTALERT QSO in the middle box and then click to send it to the message box below it looks like this
[UDP_INBOUND] [ADIF_MESSAGE] [3] [UDP_INBOUND] [ADIF_MESSAGE] [2235] JTALERT QSO it has added
[UDP_INBOUND] [ADIF_MESSAGE] [3] on its own !!
I've already set all this up on other laptop for my ic-7300 with know problems, I am following the manual step by step, but now have run out of ideas, I'm not typing this in [UDP_INBOUND] [ADIF_MESSAGE] [3] it's adding it, it self, I'll try uninstalling and reinstalling V2 again to see if that makes any difference..
Thanks again.. Paul G4YBI
Posted: 10 Mar 2020, 16:31
Paul,
To save several posts email me at address on QRZ and we will set up a Team viewer or Skpe session so that I can resolve this.
A reinstall will do nothing it just need to be set up correctly
