search tab in QSL management
Posted: 25 Feb 2014, 12:25
by ik2egl
hi
it is no so clear to me how SEARCH TAB panel should work in the QSL management/post office window
if you select a data range, there is no other available button to start the search; so what's the functionality ?
for other tabs all ok
tnx
Re: search tab in QSL management
Posted: 25 Feb 2014, 16:43
Hi Don, i agree it's not easy to understand... and i will probably change it very soon.
Anyway, open the required area (QSL/EQSL/LOTW)
flag the "Use fields as SEARCH PARAMETER"
set the search parameters in the visualized fields (es. LOTW SENT = Y)
press search button
remove the flag
select required qso to update, set informations of your needs and press save button
Posted: 25 Feb 2014, 17:41
The upload button should not disappear with the filter in use it should always be visible
