N1MM Integration
K0HB
N1MM Integration
Post by K0HB »
It appears to me (correct me if wrong) that if I configure for use of N1MM (which I use only in contests), that I will lose CAT control when I return to "normal" operation. Is that true?
If it is true, then I assume that I could build a new configuration, call it "Contest", and invoke it when I use N1MM. Then return to "normal" configuration when running without N1MM. Is that also true?
DE Hans, KØHB
"Just a boy and his radio"
Superstition Trails ----> http://OldSlowHans.com
Re: N1MM Integration
It's only a couple of clicks to restore CAT in Log4OM after your contest session so hardly worth setting up another config IMHO
K0HB
Post by K0HB »
G4POP wrote: 31 Mar 2020, 18:57 It's only a couple of clicks to restore CAT in Log4OM after your contest session so hardly worth setting up another config IMHO
Thanks, Terry, for the prompt answer.
I'll consider that as an option.
Meanwhile, is my "multi configuration" option described above a viable procedure?
DE Hans, KØHB
Yes it is but more effort but your choice
So Terry, all the other settings can stay in place? You just need to enable/disable the cat?
kd0zv wrote: 01 Apr 2020, 00:23 So Terry, all the other settings can stay in place? You just need to enable/disable the cat?
You might want to uncheck the UDP connection also if your going that route, but only to save a little CPU activity
K0HB
Post by K0HB »
Terry, I've found another solution. It is described in a new thread.
DE Hans, KØHB
