Spots from SOTA Cluster in wrong order
HB9DBM
Post by HB9DBM »
I finally migrated to V2 although still some features are missing.
I really hope that all features which from V1 get implemented in V2.
And i found a bug which may be generic to cluster spots but can be shown using the custom cluster for SOTA:
elgur.crabdance.com:7300
if you open this cluster in the morning, a sh/dx 30 will for sure show SOTA spots from last night.
LOG4OM V1 showed them correct, just in the order the come from the cluster.
V2 assigns today's date to the spots from yesterday, and this spots get then sticky all day long, newer spots from today are shown below this old spots from yesterday.
If necessary i can provide screen shots.
Thanks for this fine peace of software and your support.
Mark, HB9DBM
Mark, HB9DBM
Re: Spots from SOTA Cluster in wrong order
What is the version number you are using@ (Help/About)
Which in particular?
HB9DBM
Post by HB9DBM »
These two cause more work to do for me:
- QSL upload: Allow to specify the eQSL to which the eQSL shall be uploaded
- QSO Manager - Update - Execute Checks are missing (i.e. "Verify and fill Band values")
But I hope the error report above don't get lost, hi
Mark, HB9DBM
Mark, HB9DBM
HB9DBM wrote: 01 Apr 2020, 07:41
Do you mean select the eqsl account where you have more than one account?
This is already on our Mantis to do list
Regarding your original problem you did not state which version of Log4OM V2 you have installed
HB9DBM
Post by HB9DBM »
Yes , in V1 i could specify to which eQSL Account I would like to upload.
I have 3 eQSL Accounts.
- One for SOTA in HB9
- One for SOTA in DL
- One for Home usage[/list]
Mark, HB9DBM
You still have not answered my question - What version of log4om V2 you can see that in Help/About
HB9DBM
Post by HB9DBM »
Sorry.
it's 2.4.0.0
Mark, HB9DBM
Mark,
I have tried for a couple of hours to simulate your problem but its all working fine for me as you can see from the screen shot below.
Have you tried removing the SH/MYDX30 command - Just rem it out by adding // in front of the commend.
Dont forget to delete it from the active list and after editing the entry add it back to the active list
HB9DBM
Post by HB9DBM »
I removed the SH/X 30. Bu this cluster shows nevertheless the last couple of SOTA spots. And when you do this in the morning, it shws like in the attached picture. The spots from last night stick then all day on top of the others spots
So this was maybe a workaround but for sure not a bug fix.
Why does LOG4OM try to assign a date to the spots?? Let them in in the order as the come from the cluster, just as V1 did.
2020-04-03 09_31_38-LOG4OM 2 [Profile_ HB9DBM Acer] [Solar data info K_ 2 A_ 7 SFI_ 69 Sunspot_ 12].png
2020-04-03 09_31_38-LOG4OM 2 [Profile_ HB9DBM Acer] [Solar data info K_ 2 A_ 7 SFI_ 69 Sunspot_ 12].png (33.91 KiB) Viewed 4731 times
Mark, HB9DBM
OK Mark I managed to simulate the issue this morning, it seems to only occur early in the day.
I have referred this to lele for investigation but I beleive its a SOTA issue
