Miles VS Kilometers
Posted: 20 Apr 2020, 16:18
by W0OGH
I prefer the distance to other stations to show as miles as is common here in the US instead of KM.
I have the option to show distances in miles but everything still shows the distance as KM . I understand
this probably won't change but in V1 when i pulled up an individual station there was a chart on the right
side of the page that showed the distance in miles. I don't see in V2 any way to do that or to make the
change in the record after the qso is posted. Am i overlooking or not seeing this capability somewhere?
Help appreciated.
Larry W0OGH
[email protected]
Re: Miles VS Kilometers
Posted: 20 Apr 2020, 18:46
In the main window under the right hand map
Posted: 02 May 2020, 19:53
by W0OGH
Thanks Terry. I see the map all the time but never thot about looking down there for the miles. Now to see if i can change the KM in the QSO's to show the miles instead of KM.
Posted: 12 Jul 2020, 18:13
by NE8P
Larry,
Did you ever figure out how to change km to miles?
Thanks,
Mike, NE8P
Posted: 12 Jul 2020, 21:06
by KI5IO
NE8P wrote: 12 Jul 2020, 18:13
Larry,
Thanks,
Mike, NE8P
Mike,
From the Main UI of V2 ... Click on:
Settings / Configuration / Program Settings
You can then select your Distance unit to be either Miles or Kilometers.
Once you make your choice from the drop-down be sure to tap the check checkmark - Save and Apply.
Then you will be good to go.
Posted: 12 Jul 2020, 22:53
by NE8P
Thank you, Nolan ..... and a picture, too!
Mike, NE8P
Posted: 14 Sep 2020, 16:20
by G4XMJ
I have set the distance measurment to miles but it still shows kilometers in the recent QSO column (F7). Why, and is there a fix for this? Using LOG4OM v2.
73 Geoff.
Posted: 14 Sep 2020, 16:38
by KI5IO
G4XMJ wrote: 14 Sep 2020, 16:20
73 Geoff.
Geoff,
A search of the Forum produces many results. One is included below. Km is saved with your recent QSOs as that is the ADIF required standard.
https://forum.log4om.com/viewtopic.php? ... s#p31685
Posted: 15 Sep 2020, 10:31
by G4XMJ
Thanks.
73, Geoff.
